What did i break?
I went to the track the other day,did my burnout 1st to 2nd.I forgot to put the shifter back in drive,started spooling it up at the light(spooled up super fast)went to leave and it barley moved.Then i remembered i had it in 2nd,i put the shifter into od and it engaged ok.So i start going and it wont shift.So i can to a stop,took off and its only got 2nd gear,and all gears including first is foward.Luckly it held together for my 1 1/2 drive home at 35mph at ,2800 rpm.So what do you think it might have broke?I guess this gives me a chance to finally get the converter loosened up,its always been to tight for my turbo.
seeing i cant figure out how to edit my post,i wrote all gears are forward including first,(i ment to say all gears are foward including reverse)
