What do I need if I want to run a bigger oil Filter
the Wix and NAPA Gold (Wix) oil filter is highly recommended. Shell Rotunda diesel oil is also great.
Conrad
Conrad
I heard about this and wonder why would someone use a diesel oil when the turbo diesel can run on only to factor...detention and how well built the engine is. Where can I find this oil?
Apparently the diesel oil still has some of the Extreme Pressure (EP) additives that EPA has required be stripped of gasoline engine oil. Comp Cam recommends it for break-in of their flat tappet cams. The other option is motorcycle oil. Try Walmart, Advance Auto, Autozone.
Conrad
