That sticker tells you it will run either high impedance (hi-Z) injectors, or low impedance (lo-Z) injectors. When you change injectors, you won't have to worry about whether they are hi-Z or lo-Z; the ECM will automatically adjust.
If you DO change injectors, you WILL need to get a matching chip or have your current chip re-burned to match the injector size.
