what ET'S 1/4
turbotype87
need help with estimated 1/4 mile ET'S. Just had the engine donr not to long ago. 109 block punched .030 over with JE-Pistons, stock crank and rods. the heads are stock and freshened up with performance valve springs. Adjustable fuel pressure regulator. 50lb precision injectors. A 62mm throttle body, A 3'' terry houston downpipe with adjustable wastegate.A single stage SMC Alky kit. With a frount mount intercooler. Turbo tweak 93 octane chip, A TE-60 Turbo. The fuel pump is a walpro340 and a hot wire kit. The car was dynoed and has 398 horsepower to the rear wheels. Any guess to what the car should run in the 1/4? Any feed back is appreciated
My car dyno'd at 420HP 428TQ. Best run yet was 11.621 at 121MPH. That was with a 9PSI foot brake launch and 31psi max boost.
Unless they were dyno'd on the same dyno.... comparing RWHP/RWTQ is pretty shaky....
IMHO the TE60 turbo on 26 psi or so... on pump gas and alky... with decent timing is capable of sub 11.50 times... maybe even low 11's if the 60' time is there... you would have to 60' in the 1.5's to have a chance at low 11's.
With that being said.... if the tune isn't there... or the 60' time isn't there... low to mid 12's are more likely.
My car dynoed at 391hp & 416 torque a week ago. At the strip this weekend it ran 11.8 @ 111.5mph. I'm running out of fuel with my 36 lb injectors. I have a very similar combo as you. See my sig.
Car should make alot more power with that combo but high 11's if the dyno was right and your 60 is decent!
