streetknight
DCVING
- May 26, 2001
Does it control fueling thru the injectors or is that the cam sensor? My car is cranking just fine when it's cold, BUT after you drive it for a while and get it hot and try to crank it back it's like the timing is way high.
and every now and again when it does crank it rolls a little black smoke.
I just built the engine and heard a little clicking sound which I thought I had narrowed to the crank sensor scraping on the balancer. I took it loose to adjust and my crank sensor was in 3 pieces. The little tabs that hold it in the bracket on one side were gone. Could this be causing my problems?
Also, I know I have to have a new one. Are they dealer only, discontinued, parts store or what?
