What goes here?
87we410877
What goes at the bottom of the rear window? Are there plastic clips or something? Does something bolt over these studs? I know the trim piece goes on with small sheet metal screws but what actually holds the window in place? I attached a pic
Window is glued in w/ Butyl adhesive.
The filler is held in w/ plastic clips.
Check w/ Hiway Stars. I think they have them.
You have a pic? You’re not talking about the moulding clips right? I have those in. See the attached pic. The cutless has these plastic jobs i there. Just wondering if I’m missing something.
The screws are for the trunk side, only.
If that pic is of an Olds, I can't help you. From the pic, it looks like the ft of the Olds cover is screwed down.
The Regal has a part of the clip that grips the tangs on the cover.
No pic available.
No pic available.
I am missing the clip then. All I have is the metal trim piece and the stud as you see in the pic.
Anyone have a pic or a link to what I’m misisng here ?
