what happend?
pisano
i finally put car back together but i noticed when i put the wire from battery to alternator it made a little spark then when i got into car and turned key it was crankin up then all my lights went out and i seen a little bit of smoke come from alternator area and i tried to jump car and lights wont come on or digital dash nothing i noticed that the wire that goes into the a/c pump i cut it and it was touching steel on the car is it possible that it had power going thro that wire and i burned something? also steel line that runs oil to turbo was touching the alternator too thats the only difference from before i took car apart to now i moved it after power died tho. any ideas on what i did wrong
i didnt have the ground from battery to engine connected just the other 3 rings lol :o but anyways started it up sounds good now i need another piece of hose to finish my vacum lines and change the oil and i did my first set of heads ever '-')b
