TurboBrian
- Jul 24, 2013
I've tried getting some numbers off of them and no luck. The guy I got it from didn't know anything about it but it definitely has some mods. Any specific place where the numbers are?
SignUp Now!Like "Squid" said...You have 42# injectors...loose the hooker headers. Hooker headers cause slow spool up of the turbo plus the O2 sensor will cool down at idle causing drivability problems. Get a set of stock headers. The 237 regulator should work just fine. Get a known good chip like a TT that is matched to your combo.Lucas 42's, IIRC. Ditch the hookers, get an adjustable fuel pressure regulator, confirm the chip is for those injectors, get a scanmaster, and have some fun!
