Hey Jim,
The "turn on" knob is the boost level that the system starts spraying, should be set to 12 o'clock.
"Initial" is the starting volume of alky injected at the "turn on" point above, should be 11:30 position.
The blue "gain" knob controls the slope that the alky ramps in as boost rises. I think Julio wants you to set it on 6 and adjust boost and fuel around those alky settings. If it knocks turn up the gain.
Above based on straight methanol.
Have you been to the track with the xfi setup yet?
Mike
