what is the biggest turbo we can run
xippman
what is the biggest turbo i can run on a 85 gn in the stock location and is bolt on ? no mod. a 33 or 45 ? thanks
I had a TA62 in the stock 84 housing. Judging by how much metal was left, I doubt you could go much bigger. In my current 87 housing, I had a TA64 and I've heard you can fit the 66 wheels in there.
I believe that Jamie and Lee run a bigger turbo than that.....I'll talk to Lee later today and find out for sure
BigDaddy, are their turbos able to be duplicated or are we still up sh!ts creek as far as parts like discussed in earlier thread after I checked with John Craig/Limit.
If I'm not mistaken, Jamie found a way...............waitin' for Jamie or Lee to chime in......
Turbo
The only reason limit stopped upgrading the 86-87 turbos for the hot airs was because of the absense of the carbon seal backing plate. From my research I found that for the most part the later turbo's being designed use dynamic sealing. The difference between the two. Remenber in the earlier days of turbo charging when most cars were carb'ed? Well a carbon seal works best for a draw through type induction system (Air being drawn trough the the turbo into the induction sytem). A dynamic seal found on most modern cars, since most use intercoolers, are primarily used on push through designs and do not seal very well for our draw through type systems. I recently found a used 86-87 TA49 here on the board with a .82 A/R housing that was in need of a rebuild. Dissasembled it and it was carbon sealed. I bought a rebuild kit, reclocked the turbo, mounted it on my test engine I have on the stand and made the necessary measurements. I then cut off the end of the turbo and adapter and had a freind weld the two pieces together. I bought a throttle body adapter from turbo6x2 (Thanks Jamie !!) to straighten up the throttle body. All I can say is wow!!! I don't really have enough stall for the big .82 A/R hosuing (2800 need 3000-3200) but this sucker is pullin like a mother up top. Only probelm is with the extra air flow from the big exhaust housing my little 36lbers are runnin out real quick. Anyway sorry to keep rambling but I just had to get it out. I look to find another carbon sealed turbo and build my own bigger turbo in the future.
Glad the adapter worked for you. That's a great explanation of what we need as well good job. What size injectors you thinking about. I know fuel has become an issue with my set up and an upgrade is in the works.
here is what I've found out
To put a large comp. wheel in the stock housing, you have to have a perfect housing. In other words there has to be zero core shift in the housing where the TB mounts to the turbo. Think of the 2 studs that stick out of the housing where the TB bolts up, the hole there has to be exactly centered up between the studs. The reason being, the machining required to put the large wheel in almost eliminates any surface area to seal the TB to the turbo. I looked at Lee's with the TB off, and there is less that 1/16" of surface area on the turbo mounting face. Lee said that John Craig had to thru alot of cores until he found one that centered well enough to use. Lee also said that the turbo he has is like a 45 without the big exhaust housing. He also said that John was having trouble finding the correct seal to use in this application.....hope this clears some things up
