Drewster
Wish I Had A Clone. AKA Andrew Youlio
- May 31, 2001
Is there any alternative to the $6.50/nut stock replacement lugs from Gbody or Kirbans?
i just swapped my T rims for 87GN rims and caps. What lug nuts do you use so the GN caps will fit proper?
I just tried some Dorman 711-305. They we so tight the caps wouldnt go on even with a dead blow hammer.
The stock T lugs were better but still very tight trying to get the caps on. I was afraid i would not be able to get the caps back off if i continued with the dead blow hammer.
Do i need to manually tweek the cap ring some or am i just not hitting the caps hard enough ( i already thought i might crack the cap)
help!
Andrew
help!
Andrew
