May 9, 2005 #1 B bigal614 Supporting Vendor Joined Jun 2, 2004 Messages 1,080 Hey guys, I have a TA-60 with a LU converter (somewhere around 2900). How big of an injector should I run?
May 9, 2005 #2 P PEACHS New Member Joined Sep 24, 2001 Messages 277 I would go with a set of 72s, that way you only buy once if you ever upgrade the turbo.
May 9, 2005 #3 B bruce Rest In Peace Joined May 25, 2001 Messages 10,367 Originally posted by bigal614 Hey guys, I have a TA-60 with a LU converter (somewhere around 2900). How big of an injector should I run? Click to expand... For what kind of application?. For the street 60/65s, can make some serious HP. Plus no ecm mods, and no need for a higher idle.
May 10, 2005 #4 B bigal614 Supporting Vendor Joined Jun 2, 2004 Messages 1,080 Thanx for the help guys!! Keep the info coming!!!
May 14, 2005 #5 N norbs Classic fast, XFI, SPortsman & MS3 programming Joined May 25, 2001 Messages 6,207 I have seen 55's go 10s so you should be ok.
May 22, 2005 #6 M marleyskater420 still needs to learn Joined Aug 14, 2004 Messages 1,879 Dont do 50's. I have 50's and alky and Im at the end of my injectors with a TE45 @26psi. Do 65's,then if you decide to do alky in the future(which you should) you can put less stress on the injectors, and still maintain same the same amount of fuel.
