No way a 30lb injector would support that 550hp in the real world. Even with an FMU, you're just asking for a failure. At .55 BSFC, you'd need 100% duty cycle at 70psi to run a 30lb. Those will fail. At .55 BSFC and 85% duty cycle, you'd need to run 48psi to use a 42lb injector to support 550hp.
One thing to realize is most 42lb injectors are rated as Ford injectors at 38.5psi. Aftermarket brand injectors are rated at a higher pressure. So the real difference in a 42lb and 50lb injector is closer than the 8lbs it appears. So if you are wanting to go higher than a 42lb injector, go straight to a 55lb.
If it were me, I'd see the reailty of not sticking to 5psi for long and would go straight to the 55lb injectors. I thought I was buying a little too large when I went with 60lb injectors. The first pull on the dyno untuned they went 92% duty cycle at only 13psi of boost. I should have bought bigger.
