What speedo gear to use with 28" tires?
John Larkin
Sublime Master of Turbology
With 3.42 gears, I'm seeing a ~9% variance in road speed vs. speedometer reading with 28" tires, confirmed by the C=2¶r formula (that ¶ is pi, hehe). Is there a speedo gear that can correct this? I'm not planning on going back to 26" tires.
27.07 teeth so says the calculator. That makes sense being that the blue speedo gear stock as 30 teeth according to the chart (10% more than the recommended black gear as compared to my roughly 9% needed calibration). Now to figure out where to get a black gear.....Thanks Greg!
Anyone know the proper GM part# for the black gear. Are these the small size speedo gears that were common to older GM trans or are they huge with a metal sleeve in them. My GM dealer wasn't much help when I told him I needed a black speedo gear for a 2004r. John, would you happen to know it?
