SignUp Now!Did this just start happening?
Have you done any work on the car recently?
Does the engine turn over at all or does it not do anything when you turn the key to restart it?
How old is the starter?
Ive had this problem before. Turns out my fuel pressure was too high and somehow kept her from starting. Turned it down and bam!
I have heard of this before and will turn it down tonight.
Coil pack and module are original from 87. Car now has 62K and the starter was changed with an original GM unit when the car had approximately 59K
I am mad as hell and I am not gonna take it anymore. I am fed up!!! The car doesnot have any faults at all except for when I shut it off and try to restart. It has to sit for a while and then it will start up. I was thinking maybe it's the coil or module but the car pulls strong and nothing for me to consider that as a possibility. I swap the MAF, fuel pump relay, and ECM and no help there. Could it possibly be the CAM sensor? I was told there is no such thing as a dying cam sensor. They either work or they dont. Can someone here chime in and help me out.
