onefastjackass
- Oct 6, 2002
Ok I was woundering what timing you guys are running at WOT with 93-94 octane gas.Also what boost are you able to run??I have a ra 93 chip and am only able to run 15 lbs of boost with 94 octane or else I get Knock retard .
Direct scan says it at 22.4 degrees of timing.Is this too much??And do you think if I got the timing to 18-20 degrees at WOT it would help me run 17 lbs.
