87gnblackdemon
Don't Be Redikulas!!
- May 24, 2001
Decided to investigate trans shifting problem. So we drained fluid figuring we'd have some evidence of the problem, well this trans is as cleans as you can get, no signs of anything. I have a postons street/strip shift kit that I've been wanting to put in, I've been hesitant becuase I had the instruction faxed to me and the illustrations aren't all that great, replacing the springs doesn't sound too hard, but when it gets to removing some parts, the pictures don't help much. My dad feels with the condition the trans looks to be in, that we just replace filter, and gasket and put back together, then adjust throttle cable and see how that affects the shifts. Should I leave it alone? Will I benifit from using the shift kit in the long run? Also, in the shift kit instructions it says to not install check ball #1 and #5 if using a 9" converter, what is the stock converter??
