What valve springs are these??
jpwalt1987
Anyone have an idea as to what kind of pressure these springs will have? Here are the specs:
OD: 1.660
Installed height:1.8
Outside spring thickness: .1925
There is an inner spring that I havent measured yet.(springs still installed)
These are on GN1 heads set up for a 224/224 solid roller with .560 lift.
I am going to a HYD roller cam in the 210 to 214 range. I was wondering if I can reuse these springs. I will have them checked to see exactly what the pressures are , but that will be next week. I was hoping someone migt have a chart or something that is close.
Thanks, Jeremy
