I just purchased the SMC kit and want to get it installed on my 1984 Buick GN. If anyone has one installed already I could use some good pictures of where you mounted it and how you ran the lines. The only place I can find with enough room is between the radiator and the vapor canister, but looks like a real stretch for the flexable line to the nozzle at the turbo adaptor. What size nozzle works best with stock turbo? I have a Walbro fuel pump with adjustable fuel pressure regulator, stock injectors, Caspers ultra chip, 1987 ECU, ignition module, coil pack, MAF
What % denatured alcohol to water to oil do you mix?
