What will it run. billet 62/62
YouLikeThat
Well I've been trying to get to the track for the last month and I'm going to hit it tomorrow, hopefully. This is a last minute deal and I'm not as prepared as I usually am but anyways.
Race weight about 3500 lbs
billet 6262 turbo
FMIC
50lb injectors
Tweak 110 race gas chip. I'm running 110 leaded
3" dp/ atr 2.5 inch exhaust
RJC PP
Vig 3200-3400 non lockup converter (This might be my weak spot)
Mild build tranny (alto red clutches shift improver, stage rite and a couple billet/hardened parts)
Rear end. 33 spline axles w/ spool
M/T 295/45/17 DR tires
Metco lowers/boxed uppers/atr bar/2 air bags
That's all I can think of. I'm going to start with about 22lbs of boost and hopefully work my way up to 26-27lbs Timing on the chip is set at 27-25 I think.
Thanks,
Scott
Keep us posted, I have a 6262 ceramic, along with a few other goodies and my track is closed till March.
Back from the track.
I was having a hard time controlling the boost. Just the slightest turn and who know where is was so I ended up making the passes with 20lbs
So I went a 11.96 @110 on 20lbs of boost.
The converter is way too loose. It was shifting way out of the powerband.
What made my day was a 1.54 60' on 295/45/17 Drag Radials!
I'm happy, Just need to figure out how to control the boost and change converters.
SR
