Today I replaced the intank fuel pump because when I would go into boost, the fuel pressure could not get past 42-44 PSI before it would quickly start dropping off. The Scanmaster confirming knock and the wideband showing 12-15 in full boost confirmed this.
I asked this in another post and the answer I got was bad fuel pump.
The pump I pulled out was one of the F2000169 Walbros that I purchased in Feb '08 before they became known as the premature failing pump.
The new pump I installed is a Racetronix GS340M.
Today on the test drive I was only able to get up to 50-52 PSI of fuel pressure, and if I tried to push any harder, the pressure would quickly start dropping off.
So I have a new pump, I tightened all the hose clamps on the hose that connects the pump to the hanger, the hose I used was a new piece that came in the kit....before I drop the tank and pull the pump, where else could I check at that might affect the fuel pressure dropping off?
