What's a Regal "Sport Coupe" got that'd be worth parting out?
If it's a turbo, then the crank maybe...
Also, check to see if it has aluminum drums or radiator support. :)
Sport Coupe = T Type
Sport Coupe was the name for the Turbo Regal in 1978/82. The Sport Coupe package was re-named T Type in 1983. Obviously they would all be Carb/Turbo V6's.
no motor or tranny in it. Just body parts (mostly rusty) chassis and rear end. Header panel looks OK. Grille, bumpers, etc. Interior very rough (but complete). It's definitely an 8.5" rear but should it be posi? and what gears?
Richard
can you let me know how the headlight bezels are.
thanks
Bezels looked O.K. but had long ago been painted black (GN clone) paint's peeling off, not sure of warpage. I'll get back to you if I buy it.
A Sport Coupe with a 8.5"? You must be very fortunate that somebody swapped that in for you, because they never came with one. 8.5"'s started in 1984 for Regals.
Maybe I'm wrong about the 8.5". The grass was pretty high around this thing. I thought the two flat spots on either side of the housing on the bottom indicated an 8.5". The ones with the two "fangs" sticking down in that spot were the 7.5". Do I have it backward or something?
