Line lock will keep your rear pads cool...
The stock chip really isnt a performance chip..even tho it has 26 degrees total timing ..like a race chip..but a lot of its parameters are not intended or set for racing.
Racing the car without a scantool is russian roulette..its not a 350 chevy..you rattle the motor with knock retard you'll be picking up pieces off the track...especially running that high timing stock chip..
Direct scan is nice..but you need to see knock as it is happening..not after. In other words..if you cannot see the retard numbers increasing..recording when it blows a head gasket doesnt do you any good.
Seriously look at a scanmaster or get a knock guage with lites. this should absolutely be the very first mod the car gets..a way of seeing knock immediately.
for a car running stock boost levels..your MPH is rite. If you added a chip, upped the boost to low 20's, the mph will go up..but at 16 PSI..85 is all she wrote. Add 60 hp..then 90 becomes a reality.Make sense.
Mark, ya got a great incentive..Mike TTA89 got me set in the rite direction..he's my teacher
..now I reciprocrate the favor... Cranks are like hens teeth for these motors...Ya have to monitor knock..I cannot say this term enough times..."if" you run without knock, there is practically no limit to the performance potential of the stock motor..trust me when I say you cant hear 6 degrees of retard..but this 6 degrees will destroy the bearings in short order..I probably have 500 passes minimum and zero engine related failures..never been opened...just need to follow a couple rules..knock is absolutely RULE 1..no other will save your motor.
Sorry to sound like a broken record..you may think recording the runs on a laptop is quirky..once you get your system going..you'll be happy you did.
as far as your DS..get a spare ECM from the junkyard..as long as the 7148 prefix is on it..it will work with our cars. 86 Lesabres, Delta 88's,GM 3.0 FWD motored cars..a lot used them..just look at the motor..if it has the same coil pack as ours..the ecm should be the same. Cut that one for your DS hookup..leave your original ecm alone..and you'll need the little calpak chip from your TTA ecm..its next to the stock chip.
You have tires, tranny, inclination..and are having fun with the world's easiest car to mod.. get the electronics to verify whats happening and safeguard your investment..do it now or after a rebuild.
Feel free to email me if needed..no problemo
