Whats your favorite detail spray?
BoostKillsStres
TIRE-FRYER VIA HAIR-DRYER
Just what the subject says, what have you found to be the best? I've never used any and would like to try something I could apply quickly after a wash when I don't have time to wax.
TIA
You should use the type that is made by the same company your wax is from..
I use Zaino now.
Have used Maquires in the past and it works good too. DON"T USE IN THE SUN or on a hot surface! It'll streak like mad because it will dry before you can wipe it in/off
I haven't tried a lot of them but Meguiars Quik Detailer seems to work well for me, and it definitely works better than Meguiars Final Inspection. Most or all waxes, polishes, and detailers do not like a hot surface, and a lot of them do not like being applied in the sun.
I second Meguiars Quik Detailer, I've used that for over 2 years and it works awesome....
Actually I find Meguiars final inspection works better on black or dark surfaces a lot less streak and better shine. But like someone said it's one of many. I have tired a lot of the other stuff on the market and just get a streaky mess. Meguiars just introduced a new product line, called next generation. I'll let you know how that works after this weekend. :cool:
I've tried all but Zaino's. I like Bead-X from the folks that make Formula113. Best suff by far and it cleans a dirty surface as well in case you don't have time to wash it when it gets dusty. It can be applied in the sun and hides those scratch/swirl marks looking like the car has just been glazed. (www.formula113.com)
Previously posted by:
"turbo6x2"
"Actually I find Meguiars final inspection works better on black or dark surfaces a lot less streak and better shine. But like someone said it's one of many. I have tired a lot of the other stuff on the market and just get a streaky mess. Meguiars just introduced a new product line, called next generation. I'll let you know how that works after this weekend."
Turbo6x2:
Just out of my curousity: did you compare Meguiars "Final inspection" against Meguiars "Quick Detailer"
Between those two: I prefer the "Quick detailer" over the "Final Inspection" because the Quick detailer disperser doesn't emit drops every so often like Final Inspection does
Quick detailer disperses a finer, more constant/consistent mist than Quick Detailer.
Every body sells "quick detailer" . Fewer stores sell Final Inspection.
Quick detailer leaves no streaks, as does Final Inspection.
I used Final inspection and thought it was great till I couldn't find it one day and bought a bottle of Quick Detailer and used it a few times, however, I do not apply anything on a hot surface, as well as I try to apply it when it is cool out. I use it both on my '87 white turbo regal with factory paint and my '02 silver Z06. Works great on both.
So have you tried Quick Detailer recently?
