Whe does tranny oil need to be changed?
DynamicGN
When should the transmission oil be changed on a new killer street and what type of oil do you recommend? Thanks
Who are you?
Once a year maybe twice and anything you want. It has tractor hyd/atf mix in it when you got it so you can use that to keep it the same. But, you can use any quality atf or the such. I wouldnt recommend synthetic at this point , but they are good if used since new. :)
