TR Custom Parts
Mark Hueffman - Owner
- May 25, 2001
Bear with me on this one guys. I am running Hoosier Q/T Pros which measure 27x10.50x15 on my GN. I put them on Weld Draglite wheels that are 15x7 with 3.5" rear spacing. I think the wheels suck in the bead too much and it looks like the tire contact patch is not correct. Center of the tire is wearing more then the outer edges. If I go to a 15x8 Weld Draglite with the same rear spacing I should get a better contact patch but how will this affect fit in the wheelwell? In other words will the "tread" area still be in about the same position since I am using the same rear spacing? I would think by having a wheel 1 inch wider with the same rear spacing would just move the bead area out but not the tread? Anyone following me?
