Wheel well opening trim paint?
crisp76
What is the go to paint for the wheel well opening trim pieces? The rear ones are pretty chipped. Thanks.
Is it number 39143?
Yes.
I painted a set and I had a set powder coated, it was kinda pricey, but, IMO, the powder coat seems to be tougher than rattle can paint.
Thank You, has anyone had luck with aftermarket wheel well trim from any of the vendors?
Installed a set from Highway Stars, looks great & hard to tell the difference between these and OEM
I used the SEM Trim Black on some touch up of my original GN wheels. I used it on a lot of the trim when we repainted the car, it was the best match and I was pleased with how it has turned out.
I’ve only used SEM on my headlight bezels and was pleased with the results. I wasn’t sure if the wheel moldings were the same finish. I’ll have to try the wheels at some point since some paint is faded/worn to a degree.
