just wondering,i bought some new weld wheels and want to install longer wheel studs,front and rear,what size should they be? to run the open end lugs,3" long? and the thickness.thanx john
Sorry, I'm not that smart to quote actual lengths and diameters, but I am 99% positive that it is the same as a Chevy.
Go to your local speed shop and ask for the studs in your length that you want and they should produce some made by either Moroso or Mr. Gasket, I suggest Moroso myself. Just trying to help.
ARP 100-7708
They are almost 3" long,but they are threaded all they way,unlike other that are not threaded for the first 1/2" on the tip..
the knurld end is .4843,wich is just larger i think then stock,so they fit real tight..
