when buying a turbo??
turboN4thGen
im thinking about buying a TE61
now i have a 85 hot air, are the turbos different from the 85 and 87?? when i buy this turbo am i going to have to specify that its a 85??? or will this TE61 work on the 85 and 87? am i going to have to buy any aftermarket exhaust or anything else for this to work??
besides injectors and a stall i know that..
thanks
if your throttle body is still bolted to your turbo(stock setup)you will need to run a ta series turbo.the te series turbos have the inlet bell cast in and there's no way to bolt up your throttle body...
thanks for the info....
is there any way to move the throttle body or would it not even be worth it?? or should i just go with a TA?
