when to upgrade chip? (what mods require upgrade)
jsta6
John 15:17
I have a RA93 chip for 009's, stock turbo, stock converter.
I kept the 009's, but I upgraded to a TE44, 2800 stall, intercooler and 1/2, alcohol, MAF translator (not the plus), no cat, no mufflers, RJC powerplate, THDP, fuel pump hot wired, adj fp reg.
I run only 93 octane, and the alchy kit.
I have the boost set at 22lbs.
Do all these mods warrant a chip change? Or is a chip change only necessary when running race fuel or upgrading the injectors?
TIA!
Mods can be found here:
http://bellsouthpwp.net/s/h/shawnco/gn/gn.htm
Turbotweak alky. chip, 23psi. and 23* timing.
All day all night all the time.
Pump gas and alky. :)
You are ready.
PS: If you had the T+ you could prolly up the timing 2-4* in the Reds chip.
Just my .02.
