when to upgrade from single nozzle??
1985GN
Breaking parts
at what times and mph would it be recommended to go to the dual nozzle setup on your kit julio??? or is the single enough for low 10's and over 130mph?? if you think it best to upgrade please shoot me a price on converting to that setup. just looking for as much info as possible
If running on pump gas, I typically "rule of thumb" add it at high 10 sec range. If the car has DFI.. its easier to dial out the volume. Watch your knock activity and add alky to zero out the KR.. while removing fuel to keep the AFR in target. Good target starting point is 11.0:1.
If using with C16 and only for cooling.. single is typically fine. Target 10-15% fuel replacement. Keep adding alky until temps fall where you want.. and the power level doesnt diminish.
