Where can I get a larger than .500 boost valve
myclone
Senior Member
Ive been looking for something bigger than the "normal" .500 boost valve and Ive heard it does exist. I did a search and couldnt come up with where to get one or if they are even truely available. Where can I get said valve?
While Im here what sizes are available above .500? Im looking for ~.510 to .540ish.
TIA
Thanks Bruce. I think that may work but I have to check to see if it will work with another mod (its for a 700R4 BTW) thats already been done to the trans so expect an order if Im good to go with using it.
Bruce,
Ive read somewhere that if the boost vavle is increased beyond .500 on a 700 that the 1-2 accumulator/spring assembly "flip" mod shouldnt be done due to the higher line pressure possibly causing damage due to violent shifts. My 1-2 accum/spring is flipped (as well as the 3-4) so your input on whether I should put the accumulators back the way they "should" be with a bigger boost valve would be appreciated.
TIA.
