83ttypeboi
- Feb 27, 2003
a 84/85 downpipe for my 83 t type???
SignUp Now!Originally posted by 83ttypeboi
well i just checked my secondaries and they dont move for anything...they are attached to the area where the main throttle linkage is at right...just below that with the springs...correct? if thats true i tried opening them and they would not open!!!
Get a new belt, Did it over heat??? If it didn't over heat for long you shuld be fine.Originally posted by 83ttypeboi
OH NO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! i was drivin the regal around just cruisin and the belt to the fan, alternator and water pump? came off...wut should i do!?!?!?!?!
Originally posted by pat83t
Jim, what kinda of a damn mess you got going on over there. You know that the driveline isn't suppose to be at the same end as the driveline right?
i did let the engine warm up then i shut it off...opened up throttle and looked inside, they were shut closed, belt came off about 20 feet from house when coming home...so it ran like that for about 45 sec
