Jan 31, 2015 #1 1 1340busa New Member Joined Nov 4, 2014 Messages 3 i keep losing power to the ecm. i think i may have a loose connection, in the orange wire. where does it orginate and end?
Feb 1, 2015 #2 B bpman1234 Well-Known Member Joined Jan 24, 2011 Messages 2,002 Happened to me I had to replace it 'check your connections at the battery post to that little black butt connector jiggle those wires around it's probably already coming off just cut that little black plasticout and replace it with a butt connector
Feb 10, 2015 #3 G GNVenom Well-Known Member Joined Jan 6, 2002 Messages 2,082 Orange "MEM" wire starts at the ECM, position C16 and ends at the weatherpack shroud connector near the battery. Inspect the ECM for signs of corrosion at C16. Very common failure in a water-damaged environment.
