Where does this wire go?
kawasakki
Hey guys I have a question? Could somebody tell me what this wire connects to? I just found this laying around. Thanks.
100% sure that is your stock oil pressure sensor plug! It happens! They sell the pigtails to replace this if you want to use the stock sensor!
Ball so hard headlight wiring repair pigtail can be wired in to fix this also
Sent from my SAMSUNG-SM-G900A using Tapatalk
Thanks for the replies guys! Only problem is I just can't seem to find exactly where this plugs in above the oil filter:(
Well there might not be a spot for it. If your car has aftermarket gauges the OEM sending unit might be removed! The sensor would be coming off the brass block that is screwed into the engine block.
