Matched shift points
I got the following offline tip:
"If you feel comfortable dropping the Valve Body, remove the 2-3 shift spools. There is a spring in the stack. I have used a small washer to put behind the spring, to make it stiffer, thus increasing the rpm shift point. Sorry I can/t tell you exactly much to increase it. I/ve had mine in out many times. Mine shifts 1-2--5700, 2-3--5700."
I'll try this on my next out-of-body experience. Does anyone out there have a rule of thumb for washer thickness for the above approach?
Regarding your tip, John Larkin, I've used one of Bruce T's techniques with a twist to add weight to the light governor weight. Bruce recommends threading the hole in the light weight and using a set screw--6/32--to retain the spring. (see Strengthen the 200 4R)
I used different length set screws until I got the first gear shift I wanted. You can also add a nut to the set screw on the outside of the weight but this reduced rpm shift point too much. Just be careful about running the set screw in too far--keeps governor open--or letting it stick too far--hits the case. A 3/8 long set screw lowered mine about 300 rpm. I had ground off too much weight so this got mine back to 5500 rpm.
Now I just need to get the second gear shift to match first.
