Where to put the alky pump????
fatride
Senior Member
For those of you who have a Turbo saver, where did you put the alky pump? There's not much room under there:confused:
remove two of the rubber cushons off the pump bracket and slip it on the two bolts sticking off the front bumper mount (so the pump is behind the turnsignal), then run the nozzle feedline on top of the frame rail .
i think razor has some pics of it , if not i have a few
After taking the two rubber cushions, you want to bend off the tabs and grind them smooth.
