Well, My project for the evening was to fix some wiring problems under my dash (none of my backlighting working when i turn on my headlights) which i fixed
and then to install my water temp and oil pressure gauges. The problem is, I cant figure out where the hell to run the oil-pressure and water-temp lines through the fire-wall and into the engine bay. The only decent hole i could find is the one the throttle cable runs through, and thats sealed up nice and tight by the cable... any suggestions?? Thanks for the help guys!
