HellOnWheels
HellOnWheels
- Feb 3, 2002
I have an adjustable apply pin installed in the trans and need to know how to adjust it to try and take up some slack at the 1-2 shift, that is if the frictions ain't toasted.
Do I REMOVE or INSTALL spacer(s) to tighten up the shift and EXACTLY where is the spacer installed? ie between the servo and servo piston?
Yesterday I installed an .080" spacer between the servo and servo piston and as far as I can tell the servo cover still can be pushed in at least 3/16", nor did it help the shift!
I have read on this list of measurments from .030" to .100" would be okay for the servo play.
Would appreciate help here,
Thanks,
HOW
Thanks,
HOW
