WE4
TBcom Admin /Prayers NYFD/NYPD
- May 24, 2001
You are set then...
Install your temp sensor in the drain plug bung. 1/8th inch pipe. Done!
Would work perfect!. But to be honest, you want the temp gauge in the return cooler line but if in the pan is where you are used to it, it will fit nicely.
Bruce
We4
916-739-0510
I'd like to have one of the +5.5qt aluminum pans, but I need a temperature sensor bung welded on for my trans temp gauge. I don't trust anyone around here to competently weld one on for me. The only way I'd buy one is if it came with the bung already done.
Bruce
We4
916-739-0510
