which chip should I get?
8bud
GIGANTIC Member
Car is stock with a k&n, adjustable wastegate and a 237 regulator. Idle quality is the main thing I am looking for. Any suggestions would be greatly appreciated. Thanks.
Well, you'll get a lot of opinions on this one, so here's one :) I would try the Thrasher 92 chip since it is only $25. I also run their 100 chip in my T. I have had good luck with the PTE chip for my stock injectors also. Tim
Thrashers are known for their idle quality. However, it's recommended that you don't use a catalytic converter when running a Thrasher. Don't know if this matters to you or not. Otherwise, like tim87tr said, there's alot of opinions on this. There are also alot of good chip burners out there too that can make you a custom chip. The Thrashers seem to be the cheapest at $25 each. The going price from the rest of the lot seem to be about $75 each.
Search for Scott231, he sells the Thasher. I ran the Thrasher and I was very happy with it.
Thanks everyone. What would/could if i run the thrasher 92 with a converter?
