With a TA49 running high boost 20lbs+ you will run out of injector using the 30 lb'ers.
I run 42.5 lb 009's with a stock turbo and SMC alcy kit on my DAILY driver....right now I have a RA93 chip in it and it runs just fine.  No tip in stumble with one screen removed from the MAF.
I've also tried a Jim Testa 93 chip for the 009's and it is great for the summer time.  The Testa chip spools like MAD and is a bit much for daily driving in the wet.
I will be going to a TE44 turbo soon and will get a RA108 race chip when I order the turbo from Quad Air.  My car seems to prefer Red's chips although the RA93 seems to run a bit rich for the track.
SO...yes the 009's are fine for a daily driver.  You'll have to try a few chips to find the right one for your car.  I would try Red's, Testa's, Jay Carter....they seem to have the line on the 009's.
Good Luck,
John
