justinsane
- May 9, 2011
I have 2 dip sticks to use, one is a oem and supposed to be for a 2004r according to who i bought it from. the other is a universal lokar style. here is the problem, correct me if i am wrong here but isnt the full mark on the dipstick supposed to be level with the pan gasket as looking at the dip stick when its installed and the pan is off? the one i bought from lokar the full mark lines up perfectly with the pan gasket. the oem one the full mark is a ways up inside the case, again as looking in the trans with the pan off and the dip stick installed, if i use the oem one the oil will end up a good 1/4 to half inch above the pan gasket area. so to sum it all up do any of you have a true oem dip stick and trans that you have laying around and can tell me if the oem full mark is indeed lined up with the pan gasket or if its up in the case a little ways. thanks in advance.
