Yes......YES.......DO as stated with NEW studs.  They MUST be cycled to get the proper torque value and corresponding clamping force.  No need to change head gaskets, either, as you do not reach full torque value until you have "cycled" the nut/stud five times to set the "stretch".  Do a little research before assembling anything.
    So here is how I do it:  Torque the heads down to full torque value in five steps following the proper sequence.  I start at 40 ft./lbs, then 50, then 60, then 75, then let 'em sit for 10 minutes, then one at a time following proper sequence, I loosen the nut and then retorque to full value, then repeat five times. Then move to the next stud.  And if you rally want to be "expert" let it sit for 10 minutes and go back and loosen each nut and retorque to full value one at a time.  When redoing your head gaskets in the future (because you KNOW you're gonna
) you do not need to cycle the studs.  They have already been done.  Be sure to use the suggested lube on both sides of the washer and the stud threads.  Use you favorite thread sealer on the block side. (that is a open debate many times on here)
   When using ARP head bolts, it's wouldn't hurt to follow the same process, though everytime you torque a bolt into cast iron you are "wearing the threads out".  Though I have heard about this for 35 years I have never seen worn out threads in a cast iron block.  Stripped, boogered.......yes, worn out....never.  I suppose if you use a rattle gun and remove/replace the bolt a thousand times with out lube.......Ya, OK....that doesn't sound like a good idea.
   This process is also true when using NEW ARP rod bolts, too.  Use a stretch gauge for them, though.  Do it in a vise.
   This process costs nothing but time.  Best to make sure it is done right the FIRST time.
