Originally posted by VictoryTrans
And also does anyone know how much the TA heads are supposed flow as compared to GN-1R's, GN-1's and S2 heads?
I have a set of these heads on order. I have been told ported flow numbers but nothing out of the box so that would not be good info to compare with GN1. All I can tell you is the std valve size is 1.94/1.60 option is 2.02/1.60. The valves have been moved to the center of the cyl. allowing the 1.94/160 to be used on a 3.8 bore so the intake valve is unshrouded.
