Which lubricant for rear brakes
copo
Guys I can't remember what I used in the past to lub up the high spots in the rear shoes contact points to the packing plate and other areas for pins etc. Do I use white lithium grease or the high temp brake lub that you use on the front calipers?
...the high temp brake lub that you use on the front calipers?
If I had to choose, this would be my choice.
But, the reas shoes shouldn't need lube for this. They should slide on the plate anyway. At least I have never done it. Interesting thought.
