which parts from 85 will work in 87
The heads, crank and pistons will work for certain. Most if not all accessories won't work. The block's a little different but can be drilled for the oil drain. If I were you I'd sell the accessories, modify the block and keep the rest as a backup motor. Block should also be a 20 bolt.
