Which valve body is this
limitedv6
Stage 11 in the work's
I bought a brf core that was a good stocker well I pulled the pan yesterday and I found no wiring or pressure solenoids and the valve body bolts were about to fall out. I know it is a brf case.by what the tag says but the valve body is the wrong one and can't find any paint colors and the only numbers I can find are a 74 and a 4203*d4 and a yag. I am wanting to know if I can make it work as a spare for my car which will make decent power. I am building a stage 2 motor and expect it to run fairly good thanks in advance.
I have not talked to lonnie about it yet but the tranny I am going to run is from lonnie. I am going to use this as a backup but I was just wanting to figure out which vb it is before I have it built thanks.
Msg me if you need any other vb codes.
