I am installing a set of stock replacement bushings that include the #5 gnx bushings. I realized I must have installed these years ago but one thing I did was the new ones in the kit were about 1/2" taller than the GM ones that were in there, so I ended up leaving the GM ones in. The other thing major thing I was concerned about was the location of the top hole in the body does not line up with the bottom hole. I pushed the bushing into the lower hole and the protruding tip of the bushing will just have to get flattened down against the body. The hole is off by about 1" meaning the entire body would have to go forward by that much but all the other holes line up real good. It must have been this way since I put them in cause the center locating stub is bent over. What do you think?
paul
paul
