for sale is my 1987 Turbo T ULTIMATE SLEEPER white original paint job blue interior, floor shift, car has never been to track in its life, just recently passed california smog with flying colors not a puff of smoke when car starts.. mods are as follow, car would run easy 12's on street trimm and race a good high to mid 11's. its very fast..
COLOR – WHITE
2 OWNERS………………100,670 MILES.
APPROXIMATELY 7K MILES ON THE CAR SINCE ENGINE WAS MODIFIED REBUILT.
TEXAS CAR NOW A CALIFORNIA CAR NO RUST
SOME OF THE CARS OPTIONS:
STANDARD CLIMATE CONTROL (IN PERFECT WORKING ORDER, AC BLOWS ICE COLD WITH ORIGINAL R-12 FREON)
POWER ANTENNA (REPLACED/REBUILT)
POWER 6 WAY BUCKET (CONVERTED FROM STANDARD)
FACTORY CRUISE CONTROL
TILT COLUMN
STANDARD MIRRORS
POSI REAR
BLACKOUT TRIM
POWER WINDOWS / POWER LOCKS
ENGINE:
REBUILT SHORT BLOCK WITH STOCK PORTED HEADS
REBUILT STOCK PORTED TURBO
ASSEMBLED WITH SINGLE STEEL SHIM GASKET WITH SILICONE (FOR MORE COMP)
NEW ROD AND MAIN BEARINGS
NEW RINGS
POLISHED PISTON TOPS
POLISHED VALVES, FACE AND STEM
NEW ADJUSTABLE PUSHRODS SET AT .030 PRELOAD
BLUEPRINTED/REBUILT OIL PUMP
ADJUSTABLE WASTEGATE ACTUATOR
NEW AC-DELCO WASTEGATE VACUUM HARNESS
NEW HEAVY DUTY INTERCOOLER COUPLINGS & STAINLESS CLAMPS
NEW GREEN STRIPE 33lb INJECTORS
NEW ATR ADJUSTABLE FUEL PRESSURE REGULATOR
NEW SPARK PLUG WIRES (STOCK)
NEW AC-DELCO SPARK PLUGS
NEW AC-DELCO BATTERY
NEW MODINE ULTRA 2000 HIGH FLOW RADIATOR
NEW FELPRO FRONT/REAR MAIN SEALS (NEOPRENE)
NEW TIMING CHAIN / GEARS
NEW TIMING CHAIN TENSIONER, SPRING, AND CAM BUTTON
NEW BILLET ALUMINUM THERMOSTAT HOUSING & 160 DEGREE STAT.
NEW RJC POWER PLATE
NEW COLDAIR KIT AND K&N FILTER
NEW 3” MAF WITH TRANSLATOR
NEW FUEL FILTER (AC-DELCO)
ORIGINAL GM, AC-DELCO HOOD LINER
NEW AC-DELCO MOTOR MOUNTS
MINT INTERCOOLER AND SCOOP
NEW SENSORS: OXY, MAF, AND MAT
EXHAUST:
NEW ATR 3” CROSSFLOW STAINLESS SYSTEM
NEW ATR STAINLESS DRIVERS HEADER
NEW ATR STAINLESS CROSSOVER PIPE
NEW ATR STAINLESS STOCK REPLACEMENT DOWNPIPE
NEW ATR 3” PERFORMANCE CAT
(THE ONLY STOCK EXHAUST PART IS THE PASSENGER HEADER)
TRANSMISSION:
BRF - 200 R4
HEAVY DUTY 3,000 STALL STOCK TORQUE CONVERTER
NEW TCC SOLENOID
LEVEL 10 SHIFT RE-PROGRAMMING KIT
NEW FILTER AND SYNTHETIC FLUID
REAR:
ORIGINAL 8.5” GM LIMITED SLIP, POSI REAR W/3.42 GEARS
NEW REAR BILSTIEN SHOCKS
FRESH REAR GEAR OIL CHANGE
FRONT SUSPENSION:
NEW FRONT BILSTIEN SHOCKS
BRAKES:
REBUILT POWERMASTER BOOSTER.
MAJOR CHAIN BRAKE JOB PRIOR TO MY OWNERSHIP
WHEELS/TIRES:
SET OF (4) FACTORY T-TYPE WHEELS
NICE CENTERCAPS WITH CUSTOM POWER 6 LOGO DECAL
NEW GOODYEAR 235/60 15 EAGLE (FRONT)
NEW GOODYEAR 245/60 15 WINGFOOT (REAR)
INTERIOR:
NEW HEADLINER.
SUN VISORS RECOVERED
TINTED WINDOWS
JVC MP3 RECEIVER ADDED, ALSO HAVE ORIGINAL CASSETTE PLAYER
TUNNING:
LAPTOP WITH DIRECT LINK READY TO GO EVERYTHING WORKS CAR IS TUNED FOR 17PSI RIGHT NOW AND IT MOVES.. ALSO INCLUDED A SET OF NEW MT ET DRAGS SIZE 26X10.5X15 USED ONLY 3 TIMES AT THE TRACK WITH MY 87GN.
ASKING $10,500.00 OBO PLEASE NO TIRE KICKERS HAD MY SHARE OF THOSE, SERIOUS BUYERS ONLY CALL 310-561-9195 LEAVE MESSAGE IF I DONT ANSWER AND I WILL CALL BACK ASAP.
COLOR – WHITE
TILT COLUMN
STANDARD MIRRORS
POSI REAR
BLACKOUT TRIM
ENGINE:
NEW RINGS
NEW RJC POWER PLATE
EXHAUST:
TRANSMISSION:
BRF - 200 R4
NEW TCC SOLENOID
REAR:
FRONT SUSPENSION:
BRAKES:
WHEELS/TIRES:
INTERIOR:
NEW HEADLINER.
TINTED WINDOWS
TUNNING:
